• Contents page feedback
    Your contents page looks visually appealing, and I must say, the main titles are excellent—clear and engaging. Really well done on that!
    To further enhance your work and demonstrate a deeper understanding of the design cycle, I encourage you to align the subheadings with the terminology from the Design cycle. This will not only help you structure your project effectively but also reflect your knowledge of the framework.
    For instance:
    "Identifying the player needs" could fall under the 'Explain and justify the need' section. This is where you carefully explain and justify why addressing these needs is important.
    Similarly, "Analyse existing products" could include elements of 'Identifying the player needs', as analysing products often helps in understanding what works and what doesn’t, ultimately identifying potential needs.
    So, here’s a suggestion: Keep your existing titles, as they’re very descriptive and strong, but consider nesting them under appropriate Design cycle headings. This approach will give your contents page a well-organised structure and showcase a strong understanding of how the Design cycle underpins your project.
    Keep up the excellent work! Let me know if you’d like any further help organising or refining your contents page.
  • do remember you don't need to include all sub-sections of the design cycle.
