    2. 2026-2027 WUIS Community
    3. G6-9 Music
    4. Music class Group 2
    • JoanJ Joan
      Music class Group 2
      Alina 那另外一个呢?钢片琴也要搜索给我的!OK?
        Joan • , last edited by
      • En LinE En Lin
        @Alinaliu OK,可以了,谢谢
          En Lin • , last edited by
        • Bella yeB Bella ye
          @Alinaliu @En-Lin @Joan 我们明天不会做presentation,老师说是下个星期三
          ⊹ ࣪ ˖ ✧₊⁺ 🍮 승민 🍮 ✮⋆˙ ⊹ ࣪ ˖
            Bella ye • , last edited by
          • En LinE En Lin
            @Bella-ye 知道了,谢谢
            • JoanJ Joan
              什么下个星期三?!!😲
              • JoanJ Joan
                啊啊啊啊啊啊!!白忙活了一场!不过下次不用在做了!
                • En LinE En Lin
                  @Joan 下个星期三没课,可能是下下个星期三?
                  • A Alinaliu
                    钢片琴
                    钢片琴也叫铝板琴,起源于非洲加纳地区,由铝制条片和一个木质或塑料框架构成。钢片琴的声音明亮清晰,可作为节奏乐器、独奏乐器或与其他乐器合奏。
                    Steel-plate Xylophone
                    The steel-plate xylophone, also known as the aluminum-plate xylophone, originated in Ghana, Africa, and consists of aluminum strips mounted on a wooden or plastic frame. The steel-plate xylophone produces a bright, clear sound and can be used as a rhythm instrument, a solo instrument, or in ensemble performances with other instruments.
                    https://www.bilibili.com/video/BV1Jw411u7Kh/?spm_id_from=333.337.search-card.all.click
                      Alinaliu • , last edited by
                    • JoanJ Joan
                      Thank you Ailna!
                      • JoanJ Joan
                        https://khsj.cn/2yilnwnac7i70mc
                        • JoanJ Joan
                          Enlin,我想要问两个问题。
                          1.那个design 是要做两个或以上的产品吗?
                          2.那个我想要做那六个兴趣盲盒+一个隐藏款盲盒。那是一个盲盒是一个产品,还是所有是一个产品?
                          • En LinE En Lin
                            @Joan 1.yes
                            2.应该全部算是一个
                              En Lin • , last edited by En Lin
                            • JoanJ Joan
                              那这那这个我要写多少个?
                              那个盒子我知道怎么写。但那个盲盒,因为我要做六个兴趣盲盒加一个隐藏款,所以总共七个。那我要写七个还是一个?
                              • JoanJ Joan
                                第三个那个(我圈起来的那个)也要写在我刚刚发的那张纸上吗?
                                • En LinE En Lin
                                  https://e.tb.cn./h.jZbCtuqVaBhdPhP?tk=ekUWTrD3DLm
                                  https://ts1.tc.mm.bing.net/th/id/R-C.bde2e154cb7cfc95e36870c6a6ec4979?rik=HqNvv8UwWz8NBA&riu=http%3A%2F%2Fwww.yi-fengshui.com%2Fuploads%2Fallimg%2F190723%2F1-1ZH31P52Q26.jpg&ehk=2aGhIzIRfJp9bcN5Ta0xzuJOqRptrNpMkRtjOnmJrwI%3D&risl=&pid=ImgRaw&r=0&adlt=strict
                                  https://img.alicdn.com/imgextra/i3/2395688374/O1CN01TyVTmB2BjLnlBicw9_!!2395688374.jpg
                                  picTEL.pptx
                                  enlin yy(zzb).ai
                                  • CartaC Carta
                                    This post is deleted!
                                    Tabang.. (// _×)
                                    Grabe ang sakit sa akong abaga... Sa akong tan-aw, kinahanglan tingali ko og cast..(:̲̅:̲̅:[̲̅:♡:]̲̅:̲̅:̲̅:̲̅)
                                    Maayo na lang gani kay gibugkosan ko ug gibutangan og berde nga pahumot!!🩹
                                    Pipila na lang ka bulan, unya maayo na gyud ko! 🩹
                                      Carta • , last edited by
                                    • JoanJ Joan
                                      Enlin, 我想看看一下你写的中文Presentation的事件,可以吗?
                                      还有一件事,就是明天是有音乐课的吧,我们需要做演讲稿,还是直接照读PPT上面的?
                                      • En LinE En Lin
                                        @Joan 可以哪一章?现在就要?
                                        照读PPT上面的
                                        • JoanJ Joan
                                          第五章和第六章,我是不是要的太多了?要是不行的话,你随机给我一章都行,Thank you !
                                          • JoanJ Joan
                                            对,现在!
                                            那你说音乐课那个是按照PPT来读是吧?那我们可以先分配,谁先读谁先读这样的!
