• Develop design ideas - Feedback
    selvia - developing designs -19-3-25.pdf
    Detailed Thinking: You’ve done a great job developing your idea with lots of detail. It shows you’ve put thought into your concept and carefully considered its elements.
    Strong Foundation: Your effort provides a solid base to build on as you refine your ideas further.
    Suggestions for Improvement:
    Explore Multiple Concepts: At this stage, aim to brainstorm a variety of high-level ideas rather than focusing too much on one. This will give you a range of options to choose from and help you decide the best direction to take.
    Leave Room for Refinement: Keep your initial concepts broad so you can adapt and develop them later during deeper design stages. For example, instead of finalising too many details now, outline the key features of several potential ideas.
    Balance Depth and Breadth: While it’s great to see the detail you’ve included, remember to capture additional ideas that may also work. This helps create a thoughtful comparison between multiple approaches.
    Overall, this is a promising start. Try adding a few more high-level ideas before diving deeper into any one concept. Keep up the great work!
